Remote start install w/alarm
Old Oct 12, 2018 | 07:15 PM
onecrazygm's Avatar
Default Remote start install w/alarm
Hello it's been a long time! Not sure if I'm in the right section and yes I have used the search button and I can still not figure out whats going on. I recently tried to wire in a remote start and followed the directions to a T. what I'm trying to figure out is why it won't stay powered on and will not crank. It's a compustar alarm module is cm600-as. My relay was hooked up the right way reds to a consistent 12v(red wire under ignition) the green which called for 12v ignition(which was pink wire) and the yellow (cut in half ) start side and then ignition side through relay , white to ac/blower acc, and black to ground. has anyone done a remote start that can help me out ? I have hp tuners and disabled the vats but should I still have the resistor? any thing helps
File Type: pdf
Old Oct 12, 2018 | 07:17 PM
onecrazygm's Avatar
Also this is a 98 trans am. tach sense was hooked up and learned and hood switch was installed and working too. Does the started wire go to another relay somewhere?
Old Oct 12, 2018 | 07:48 PM
8.Lug's Avatar
Without disabling or bypassing the VATS the car isn’t going to start.
Old Oct 12, 2018 | 08:45 PM
onecrazygm's Avatar
I used hp tuners to disable the vats. Unless there is something else I am missing.
Old Oct 12, 2018 | 10:33 PM
You're fine. He's an alarmist...
Old Oct 14, 2018 | 08:23 PM
onecrazygm's Avatar
Bump.
