VE to Cranking VE table excel sheet
Old Oct 24, 2018 | 04:58 PM
TPIZ92's Avatar
Default VE to Cranking VE table excel sheet
Can someone post this up? Can't download it anymore. I think it was made by a member named Redhotsupra or something like that. Thanks in advance!
Old Oct 24, 2018 | 07:15 PM
truckdoug's Avatar
oh man I cant even find his blog anymore, i wonder if it got taken down?
Old Oct 24, 2018 | 07:39 PM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
http://redhardsupra.blogspot.com/ all ded.
Old Oct 24, 2018 | 08:25 PM
truckdoug's Avatar
bummer
Old Oct 25, 2018 | 11:58 AM
TPIZ92's Avatar
I had a minor cold start issue after the blower. Started with raf and it came in pretty close to stock as expected. I had never touched crank ve so I just removed 10% (which just happened to bring the values closer to what the actual ve values are) and it made major improvements. So I filled in 400,800 and 1200 and then interpolated between them and then down to zero I think I took out like 10% and interpolated up to 400. The car fires up and doesnt "stumble to life" like it did. I wanted to compare my results to this spreadsheet I read about.
Old Oct 26, 2018 | 01:12 AM
tsench's Avatar
here ya go
File Type: xls
Old Oct 26, 2018 | 01:52 AM
TPIZ92's Avatar
You're awesome, thank you!
