Feasible to create auto-lock from ODBII?
Anyone know if it's possible to rig something up from the odb port to send a negative signal that I could hook to the door lock? Would be good to send it to the unlock at ign off.
I've been looking to see if there is any aftermarket thing for this but haven't run across anything.
Not that you're going to spend the money to make the switch but an aftermarket ecu would be able to make that possible. I run a Holley system that locks out reverse at speeds above 5mph.
Since your car is an automatic what would be simpler is setting a switch to activate a relay that locks the doors when you put the car in gear and unlocks them when you move back to park. Some aftermarket alarms will do this.
You'd need a micro controller
1 Mcp2551/2515 combo, 2 output resistors and 2 caps
1 linear voltage regulator/I/O caps to feed the micro controller and CAN chips as well as stabilize the voltage.
2 Npn transistor and gate resistor
2 Songle micro relays - These are good for 10 amps
Send the pid request 0x01 0x0D every 100-200ms to get vehicle speed then read the response and convert it to MPH.
A simple program something along the lines of.......
if (speed > 10 && LockPin == LOW) { digitalWrite(LockPin, HIGH);} // turn on lock relay if it's not on and speed is more then 10 mph
else if (speed > 10 && LockPin == HIGH) { digitalWrite(LockPin, LOW);}// if speed is more then 10 mph and lock relay is on turn the relay off
if (speed < 10 && UnlockPin == LOW) { digitalWrite(UnlockPin, HIGH);}// turn on the relay to unlock the doors when speed is less then 10 mph
else if (speed < 10 && UnlockPin == HIGH) { digitalWrite(UnlockPin, LOW);}// IF the unlock relay is on then turn it off
That gives you an idea how simple it is..you could add a timer to the above code to control how long the lock/unlock pulse from the relay lasted if it didn't turn on the relay long enough to activate the locks fully. Hell could even add a delay so that it'd wait X number of seconds before trying to activate the locks again so the locks aren't cycling on and off at parking lot speeds.
If your handy with a soldering iron and spent a couple of hours reading on basic programming for something like an Arduino and a few more hours writing your program and assembling the parts you could build this your self in a couple of nights for about 15 bucks worth of parts on a blank pcb. Hell you could just but an Arduino, a CAN shield and micro relay board for around $30-35 bucks but you'd still need to come up with a regulator to step the voltage down to something a micro controller can worth with and it'd be a bit larger.
Most BCMs can be configured to lock the doors when you put the trans in drive or when it reaches certain speed and unlock them when the shifter is put in park.
Aftermarket alarms can only be programmed to lock when ignition is ON and unlock when switched OFF (at least most common models)
