CKP Relearn for Swap application
Old Oct 31, 2018 | 10:58 AM
alf36f's Avatar
Default CKP Relearn for Swap application
02 Camaro SS 5.7L w. 4L65 using 12200411 PCM (from same donor vehicle), installed in my 36 Ford PU. Relearn procedure calls for "setting the park brake" (along with other sequential steps). As there is no circuit in my application to tell the PCM this information, How can I provide this "Instrument Panel Cluster (IPC)" data to the PCM? Can I provide 12V. to C1 pin 80, or C2 pin 80? bridge the two??? These appear to be the pins used for IPC input, but I have to yet find more info.
Old Oct 31, 2018 | 11:28 AM
truckdoug's Avatar
you can just disable the parking brake code and it'll case learn just fine
i'm not sure what wiring diagram you have but pin 80 on any connector c1 or c2 for both the p01 and p59 computers is a ground
Old Nov 1, 2018 | 09:43 PM
alf36f's Avatar
How do I disable the parking brake code? Tech II, or something like HP tuners, or take it somewhere to be Flashed? Oh, and thanks for the input (need all the help I can get).
Old Nov 2, 2018 | 07:00 PM
truckdoug's Avatar
yes either the tech 2 or HPT will do it
Old Nov 2, 2018 | 08:21 PM
alf36f's Avatar
Thanks, I'll try the Tech 2, 2morrow. (and let you know)
