Not shifting at WOT
I've been trying to get my transmission to shift at WOT based off 6400 RPM.
I've set WOT shift speeds from 1-2, 2-3, 3-4 to 0. I then set WOT RPM to 6400 1-2, 2-3, 3-4.
It completely bypasses this setting and revs until it hits the fuel cut off.
If I set it to 6000 and the mph in check, it shifts at about 5970. However, anything over 6000 it will bypass everything and rev until it hits fuel cutoff.
Can someone take a look at this file and see if there is something to adjust?
EDIT : Bluecat software fixed issue
