HELP with 2-step install
Old Jul 9, 2004 | 03:56 PM
SSHOTROD's Avatar
Unhappy HELP with 2-step install
After reading through the directions I'm a little confused on how to connect the activation inputs ( gray and white wire)
I want to activate the 2-step using my clutch (six speed trans)
On/Off operation:
On/Off operation allows the user to activate and de-activate the 2-step manually.
White wire (arming switch): Momentary switch to ground. Normally open, close to activate.
Gray Wire: Connect to ground or parallel with white wire.
Relay control output:
The relay outout provides a switched ground (yellow wire) whenever the 2-step is armed or active. This can be used to deactivate a nitrous system that normally uses a wide open throttle switch for activation of the nitrous, or for an indicator that the 2-step is active.
Any help greatly appreciated?
