What tune for PCM and TAC to work
Old Dec 26, 2018 | 07:50 PM
Vetteman61's Avatar
Default What tune for PCM and TAC to work
Hello,
All parts of my swap are from the same 2004 Avalanche (TAC/Pedal/Throttle Body/Etc) except for the PCM, which is a service code 12586243 from a 2004 Express Van. I had my tuner install a 2004 Tahoe on the PCM, however he said he may have put in a 2004 Avalanche. I have started the engine and cannot get the pedal to respond. I have checked the ohms for the pedal and I've checked the power and ground for the TAC and all are working.
Is there any reason an '04 Tahoe or '04 Avalanche tune would cause the TAC to not work with this setup? From what I understand installing the tune should allow the throttle components to work since they're all from the same vehicle and from what I've read so far the Express Van PCM, even though it came with DBC, is compatible with DRW. Is there anything else the tuner would need to do to make this work?
*Edit: I was able to get ahold of the tuner tonight and he confirmed it was a 2004 Avalanche tune he put on the 2004 Express van PCM.
Thanks,
Old Dec 27, 2018 | 12:58 AM
subeone's Avatar
2004 avvy file should run it no problem. That is, unless the ETC section doesnt have a "1" under system options for GMT800. If it has a 0, that is your problem. If not, wiring, tac, pedal or TB related.
Old Dec 29, 2018 | 10:28 AM
Vetteman61's Avatar
I believe what you mentioned here is what the problem was. Thought I can't remember exactly what the exact code was, it was that the GMT code had not been switched over to the truck rather than the Van. Thank you for the reply.
