Startup tune help.
Old Mar 13, 2019 | 03:28 PM
chr45gt2's Avatar
Default Startup tune help.
What parameters should I change in HP tuners for the following mods-
227/235 110+3 cam( has 11 degrees overlap)
Ported 799 heads milled to 62cc (compression around 11.1:1)
Dorman 615-901 intake with Warr 92mm TB, 85mm MAF, FTP 98mm lid.
SLP longtubes.
Old Mar 14, 2019 | 11:50 AM
Jgaines8679's Avatar
What ecm are you running gen 3 or gen 4?
Old Mar 14, 2019 | 02:07 PM
chr45gt2's Avatar
Gen 3. I got it running and holding a steady idle. Just need to bleed the clutch so it can go into gear now and I can start logging data.
