Knock only in PE
Old Mar 19, 2019 | 04:55 PM
VandykeT/A's Avatar
Default Knock only in PE
04 Sierra 6.0 with a small cam. I’ve noticed I’m getting full 8 degrees knock anytime I enter PE. I had PE set at 60 tps and the second it surpasses it instant 8 degrees. I can turn PE off with the rpm delay and no knock. What is causing this? Truck is in SD right now. I can post a file if needed.
Old Mar 19, 2019 | 05:30 PM
DFORESI's Avatar
Have you changed any of the knock sensitivity settings or any of the transient mode parameters? What about anything in the Spark >> Retard tab? A cal file would be helpful, without it, we would just be throwing darts.
Old Mar 19, 2019 | 05:47 PM
VandykeT/A's Avatar
Berlin SD 8.1 inj.hpt
Old Mar 19, 2019 | 05:59 PM
VandykeT/A's Avatar
I think I figured out my problem. I took burst knock the wrong way. Tried to remove it by zeroing but I turned it to the max instead.
Old Mar 20, 2019 | 07:59 AM
DFORESI's Avatar
Good work! It's easy to get something in there wrong.
