Tune "off" after trans swap?
Old Mar 27, 2019 | 06:20 AM
StolenFox's Avatar
Default Tune "off" after trans swap?
I originally built my 6.0L LS swap BMW E39 with a 4L80E that was controlled by a Fast EZ-TCU and had the PCM tuned (04 GTO) locally. Since then I've switched the car over to a manual 6-speed (TR6060) and I'm wondering if the tune needs to be revisited.
Thoughts?
Thanks!
S.F.
Old Mar 27, 2019 | 10:08 AM
dw456post's Avatar
Are you the guy that used to build H pipes?
It sounds like you divorced the PCM from the trans a long time ago. The tune might only change from the different loads in the gearing, but that wouldn't be much, just a little spark and fueling touch up. I'm guessing that you don't have a working speedo?
Old Mar 27, 2019 | 12:17 PM
StolenFox's Avatar
Yes, I used to build H-pipes and Axle Backs for the 04-06 GTO and the 08-09 G8's. You are correct in that the PCM does not care about the trans and hasn't since day-1 but I am curious about the gearing differences causing a less than ideal tune. 4L80E and TR6060 ratios are quite a bit different if I recall correctly.... Speedo is working fine as its driven off the rear half-shaft (BMW's are weird) and the TR6060 is sending the speed signal to the PCM.
Thanks!
S.F.
Old Mar 27, 2019 | 12:37 PM
If an engine is tuned correctly for all circumstances, it should run correctly no matter what. The only time an engine should need tuning for a different setup is if/when some parts of the A/F table(s) aren't correctly populated, if indeed they are populated.
Old Mar 29, 2019 | 06:35 AM
StolenFox's Avatar
Ah, very good then.
Thanks to all who replied!
S.F.
