MAFless tune for LS1 with cam
Old Mar 31, 2019 | 04:03 AM
90Vette's Avatar
Default MAFless tune for LS1 with cam
Hi, im after some help.
Can anyone share a start up tune or similar specs to my engine ?
no MAF 2004 LS1 with LS6 intake / valley cover / TB
1 3/4" Long tube headers
WS6 Hot cam 218/227 .600/.600 112+2 LSA
Dual 2.5" exhausts
OTR intake
Dominator 3000 stall
Built 4l60e auto
I can share
HSV FACTORY 285 KW MANUAL AND AUTO BIN FILES INCLUDED (SUITS VT TO VY 512KB LS1 PCM)
SS FACTORY MANUAL AND AUTO BIN FILES INCLUDED (SUITS VZ 1024KB LS1 PCM)
300KW MAFLESS MANUAL AND AUTO BIN FILES INCLUDED ALLOWING FOR USE OF OTR INTAKE (VT TO VZ PCM)
Thanks !!
P.S is there a easy way to prime the LS1 prior to starting ?
Is it worth getting a oil pump in bucket etc and pumping in the oil into the engine
Old Mar 31, 2019 | 05:45 AM
madmann26's Avatar
There is a oil plug on the driver side just for this purpose.
It has an Allen head on it. Pour some oil in there.
Old Mar 31, 2019 | 06:36 AM
ChopperDoc's Avatar
Can also be primed by pulling the ignition relays from the fuse box and your spark plugs and cranking it for a minute or so. This is provided you used assembly oil on everything as you assembled it. I don't recall what the manual says as to how long, but this is another way to make sure you get oil primed and where it needs to be before firing it up.
Old Dec 21, 2020 | 11:53 PM
Modz2014 modz's Avatar
are you willing to share the bin files please
