Hate to do it but another what am i missing idle thread
Old Apr 14, 2019 | 03:01 PM
SMOKY's Avatar
Tenured Member
Default Hate to do it but another what am i missing idle thread
2000 formula with an 6.0, tr228r, 80lbs dekas, boost regulated, china gt45 turbo, 85mm throttle body, ls6 intake. Im running a p59 computer with iac on the firebird and having a startup flare then die. It will idle pretty good if I keep the throttle at around 10% and slowly lower it to 0%. But initial cold start it dies.
Old Apr 14, 2019 | 03:56 PM
JHZ28's Avatar
startup airflow delay u have all zeros I would put 150 across the whole thing might want to try to open up the throttle blade some also
Old Apr 15, 2019 | 12:54 PM
SMOKY's Avatar
Tenured Member
Tried that not much of a difference. Got the car fired up and idled till fully warmed up. Noticed the IAC counts were almost maxed so I enlarged the throttle body bypass hole in reference to this http://www.silveradoss.com/forums/to...sing-hptuners/. Now she starts pretty well. Needs a few tweeks but ill figure it out the rest of the way. Thanks again.
Old Apr 15, 2019 | 09:36 PM
LilJayV10's Avatar
i would have opened up the TB blade and did a TPS/IAC reset before I drilled the hole bigger to get the hot IAC counts where they need to be. Then play with the RAF and startup airflow.
Old Apr 15, 2019 | 10:38 PM
SMOKY's Avatar
Tenured Member
Tried that and went to .75v and still was in the 280s hot. Tried lowering ve to use less fuel, added to raf back and forth. She just wanted more air.
Old Apr 17, 2019 | 10:37 PM
ChopperDoc's Avatar
Idle tuning sucks. Have you watched my guide on tuning the IAC? Give that a try. 90% of it is actually in the throttle blade adjustment, not the IAC. You want the hot counts down in a range from 20-60 or so, could be a little higher or lower, but it gives it room to open when the car is cold.
Old Apr 18, 2019 | 05:39 AM
SMOKY's Avatar
Tenured Member
I actually just watched it and will be using your math to get the IAC adj. I watched both videos actually.
