--IAT vs Resistor vs Reported Temperature Hi, when going SD you have to install a iat in front of the TB, what iat model are you using? Do the model is related to the ecm model? Do all those iat sensor all have the same resistance vs temps value? If not can it be fixe with HPT? Just try to understand the normal way to do it to be able to go one step further. All those question comme down to one mod, if I remplace the map sensor on my ls3 intake with a T-map to eliminate the normaly use iat sensor in front of the TB, what gone apen with the resistance value of the new T-map, Do I have to look for a specific T-map with specific resistance vs temps value or I will be able to fixe everiting with HPT? What do you think of the T-map option? |
Not sure if the PCM will recognize the "IAT" signal from a TMAP, as those are simply on different reference wires. I would assume you could wire the temp signal from the TMAP into the IAT input on the PCM, but you will have to know which wire is what. The other option would be installing the IAT in the manifold in the alternate MAP location normally provided on aftermarket intakes. If not, drilling a hole in an area behind the TB in a suitable location is another way to get it done. Yes there is a table in HPT that can adjust the IAT sensor cal. |
Originally Posted by ChopperDoc
(Post 20098626)
Not sure if the PCM will recognize the "IAT" signal from a TMAP, as those are simply on different reference wires. I would assume you could wire the temp signal from the TMAP into the IAT input on the PCM, but you will have to know which wire is what. The other option would be installing the IAT in the manifold in the alternate MAP location normally provided on aftermarket intakes. If not, drilling a hole in an area behind the TB in a suitable location is another way to get it done. Yes there is a table in HPT that can adjust the IAT sensor cal. Very happy that HPT have table to ramp the new IAT value. |
© 2024 MH Sub I, LLC dba Internet Brands
