Codes c0550 c0896 on a 2002 camaro z28 automatic
Old May 20, 2019 | 06:07 PM
Z28MEXICO's Avatar
Unhappy Codes c0550 c0896 on a 2002 camaro z28 automatic
Hello, i have a big trouble with my 2002 camaro z28, when i drive my car around 20 or 30 minutes, the ligths ABS INOP, BRAKE AND ASR comes on, then my transimission fails.. start on 3gear and the pass and gear simply dont work
i really appreciate your advising
the abs scaner told me the codes C0550 AND C0896
THANKS A LOT
Old May 21, 2019 | 06:22 AM
ChopperDoc's Avatar
Did you bleed the brakes recently, or have a line leaking? This sounds like the ABS module is either bad, or our of "home" due to bleeding or a leak. This isn't related to the PCM, as the BCM controls ABS, and requires a Tech II scanner to diagnose or fix. A bad ABS will cause failure of the traction control as well. Could be a bad wheel sensor too, or even wiring. What has been done to the car and what mainentance has been done recently?
Old May 22, 2019 | 06:13 PM
Z28MEXICO's Avatar
Default Thanks
Originally Posted by chopperdoc
did you bleed the brakes recently, or have a line leaking? This sounds like the abs module is either bad, or our of "home" due to bleeding or a leak. This isn't related to the pcm, as the bcm controls abs, and requires a tech ii scanner to diagnose or fix. A bad abs will cause failure of the traction control as well. Could be a bad wheel sensor too, or even wiring. What has been done to the car and what mainentance has been done recently?
every thing its okay.. I think the abs module is bad
