Wideband and mpvi2 help
Old Jun 8, 2019 | 10:30 PM
Zproject28's Avatar
Default Wideband and mpvi2 help
So here’s the scoop. I’m looking to purchase a wideband for my build. I have the mpvi2, however I would like to do the bypass for now, instead of the pro feature. At a later date I may upgrade to pro. So what I’ve gathered is you can use a serial data to usb to wire up a wideband and use an extra USB port on the laptop. Will the gauge then only read when the laptop is hooked up? I think I have a pretty good idea of what needs to happen to hook it up. However if someone has a good write up or can refresh me I’d appreciate it. Also, I am attaching pics of the combo I’m looking at. If anyone see’s any issues with the combo I’d also appreciate it, or suggestions of better combos. Thanks in advance
Old Jun 8, 2019 | 10:32 PM
Zproject28's Avatar
Old Jun 8, 2019 | 10:33 PM
Zproject28's Avatar
Old Jun 9, 2019 | 09:36 AM
SE-R Spec's Avatar
Try the hp tuners forums. I’m certain serial ports 1 and 5 are used on the green plug but I can’t remember which one the signal wire goes into.
Aem widebands are easy to log in HPT because they already have the parameters set up in the software. All you need to do is add a channel with the aem wideband you are using then add your wideband to the charts. It has to be in the channels list first before anything will show up in graphs, charts or gauges.
EDIT: pin 1 is the signal, pin 5 is the ground
https://forum.hptuners.com/showthrea...EM-wideband-up
Old Jun 16, 2019 | 10:27 AM
Kevin Fodge Jr.'s Avatar
I'm not sure if they converter will work, the plug looks right, but I believe they use an rs-232 serial protocol. I used an insignia adapter from bestbuy and just cut an old serial cord in half. But the wideband gauge will read whenever it's on, not just when plugged into the laptop
Old Jun 16, 2019 | 10:28 AM
Also, make sure that the serial port ground is also grounded to the vehicle
By Brett Foote | 2026-06-04 05:00:17
