Knock sensors
I have a knock sensor harness i can check later to see how they are wired into the plug.
I believe it knows which sensor the input is coming from. There's an error code for each sensor. But my log file isn't showing any knock retard, so I'm a little stumped here. Would it possibly be found under another name?
I believe it knows which sensor the input is coming from. There's an error code for each sensor. But my log file isn't showing any knock retard, so I'm a little stumped here. Would it possibly be found under another name?But I took the loom off the harness and it is a single wire running to each sensor. So the computer knows which is which. The plug for the knock sensors to the main harness is actually on top of the manifold under the engine vanity cover. it should have a metal clip on the pig tale that holds it in place. It was the only pigtail that had that i think.
