Street tune fueling
Old Jun 28, 2019 | 11:23 AM
99blkfrc99's Avatar
Default Street tune fueling
I'm just trying to learn so be kind. If I am getting a street tune, how would one tune the air/fuel with a gauge such as a wide band? For WOT and cruising. Just curious. I've always had tuning done on a dyno with a sensor. So how, or what to look for on the street? Thanks
Old Jun 28, 2019 | 11:39 AM
ChopperDoc's Avatar
For part throttle areas, provided you are using a closed loop tune of some kind (fuel trims aka STFT's) you can tune the part throttle areas using them. The wide band is required for full throttle and high rpm areas because Power Enrichment disables fuel trims. So to do anything into WOT you must have a wideband hooked up and logging.
Check out my guides for more, pretty sure the videos will answer your questions. If not, feel free to ask.
Old Jun 28, 2019 | 03:25 PM
99blkfrc99's Avatar
Thank you.
