hard misfire, but no codes
Old Jul 12, 2019 | 11:22 PM
dannyz's Avatar
Default hard misfire, but no codes
Car has developed a hard misfire, both at idle and under load.
No codes are showing on my diablo handheld, no flashing ses light.
Fuel pressure is at 57psi under load, 60 psi at idle.
All plug wire's are tight.
It happened the first time a couple of days ago, misfiring was bad, but went away after just a short drive and was totally normal.
it came back with a vengeance today, and is not going away on it's own.
It's getting dark now, so where should I start in the morning?
Old Jul 12, 2019 | 11:34 PM
Random misfire or regular, as in the same cylinder(s) missing?
Old Jul 13, 2019 | 07:28 AM
Kjduvall's Avatar
I've had very similar situation when my front o2 sensors went to crap. Replaced both with ntk . And no service light ever came on. Solved my issue.
Old Jul 13, 2019 | 03:30 PM
dannyz's Avatar
Same cylinders
Old Jul 13, 2019 | 03:31 PM
dannyz's Avatar
Replaced both O2's with bch 13111's
