Torque management tables
Old Jul 13, 2019 | 10:33 PM
field57's Avatar
Default Torque management tables
Does anybody know what the factory torque management “torque reduction”
tables should look like for an 05 4L60E? The mail order tune I got is all at zero but I would like to get that part of it back to factory settings. Thanks
Old Jul 13, 2019 | 11:09 PM
kingtal0n's Avatar
Just download a bunch of random tune files that use the same transmission and sort of copy over the ones that makes the most sense. Use comparison feature to blend in whatever you need.
it also isn't difficult to adjust torque mgmt by driving-programming because:
1 Use trans performance switch mode to gain 2-maps and use it to compare in real time.
2 minimum timing is set by Ecu so "too much mgmnt" just caps out on the max retard
Old Jul 14, 2019 | 11:53 PM
SoCalDave's Avatar
I know it's not an '05 4L60E, but this is from my '01 4L60E trans.
