V6 Computer
Old Jul 20, 2019 | 12:34 AM
98LS1auto's Avatar
Default V6 Computer
Are the computers in the 99-02 V6 Camaros the same as the 99-02 V8 Camaros? Just with different tunes obviously. Thanks.
Old Jul 20, 2019 | 08:28 PM
01CamaroSSTx's Avatar
Anyone?
I'm not sure they're interchangeable and curios to know myself as I have a 99 Camaro V6 car that's now my future strip car. The good news is that 0411 ECM's for V8 cars are relatively cheap though.
Old Jul 20, 2019 | 11:53 PM
brandon6.0's Avatar
Yes they are the same. Just need to be segment swapped over to a v8 platform.
Old Jul 21, 2019 | 09:43 AM
Does that mean just install the V8 engine and harness and your done? My concern is the throttle setup on the V6 car which is drive by wire. I'll be going to a drive by cable so do I just need to remove a pedal and cable from a V8 Camaro to replace the one in the V6 car?
Old Jul 21, 2019 | 07:04 PM
LSX Power Tuning's Avatar
Its going to be more work than that for the swap. Its easier if you have a whole V8 parts car.
Old Jul 21, 2019 | 09:25 PM
So its going to be more well then how much more and be specific? For me its a strip car so I'm not looking to put everything the V8 car has so for me its the bare minimum. If its just an engine harness, k-member, rack-n-pinion and steering shaft that's not a big deal. I don't plan on using the transmission, fuel system or rearend in the V6 car anyways. I'm more concerned about the electronics and wiring so can anyone who knows what really needs to be done share their knowledge as to what changes need to be made to make the conversion. This may not be the correct forum to ask this in the first place but I found the post here and inquiring minds want to know.
Old Jul 22, 2019 | 10:38 AM
brandon6.0's Avatar
Swap over the harness, pedal etc.
If your ecu has the iac and tps drivers it can be tunes for a dbc v8 setup! Look it up on google and open it up and look for the drivers!
