Tuning VE table below 15KPA
Old Sep 18, 2019 | 07:50 PM
Corey Hunt's Avatar
Default Tuning VE table below 15KPA
Hey Everyone
Having a lean spike issue. Typically occurs between 1500 and 2300 when letting off the throttle (tps going to 0%). My MAP KPA drops to 12-14 KPA for a second and my wideband spikes to 16-17 AFR. I've tried fattening up the VE table in the 15-20 KPA rows but it did not help.Should i be seeing a MAP value this low? My VE table doesnt have a MAP value this low to make any adjustments. I have DFCO and CFCO turned off as I thought that might be causing it, but the issue persists. Im kind of lost where to go from here. Any suggestions would be great
Car is an 89 Firebird
95 LT1 from a caprice
24x Torqhead conversion
Cam from an F-body LT1
1.6 rocker arms
Hedman mid length headers, ORY to 3 inch magnaflow
Old Sep 19, 2019 | 02:04 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by Corey Hunt
Hey Everyone
1.6 rocker arms
Is this causing a return to idle issue? If not, don't worry about it. If you get zero fuel off throttle, it is only an issue if it does not return to idle correctly or causes a hiccup when you get back on the throttle.
Old Sep 19, 2019 | 08:58 PM
Corey Hunt's Avatar
It doesn't seem to cause any issues returning to idle. Thats good to know, I'm pretty new to tuning.
Thanks!
Old Sep 24, 2019 | 06:49 PM
rpturbo's Avatar
I doubt at that RPM it is going into dfco, but dfco will do that also. Make sure that is disabled when tuning, and set it back up when done if you want the extra help with mpgs. As said, it is fine going lean on decel. That is exactly what dfco does.
