GM gen 3 auto to manual conversion
Old Sep 19, 2019 | 09:17 AM
GB8118GB8118's Avatar
Default GM gen 3 auto to manual conversion
Hello,
I have a gen 3 5.3L engine mated to a Porsche 930 manual transaxle. The tune file is from a stock 2001 GMC Yukon which was mated to an automatic transmission. The VE and MAF tables are dialed in (ported heads, cam, LS6 intake installed backwards, and headers) but I am experiencing an annoying idle problem where the desired idle speed will increase by 125 rpm after running the engine for a short amount of time. Reading through several posts I'm gathering that I should be looking for a comparable vehicle with a stock manual tune? VSS is also not wired in so the PCM does not know how fast the vehicle is moving.
If I do need to change over to a manual tune is there any way to do this without having to purchase another 2 credits?
I went to HP Tuners repository and grabbed a 2000 Camaro manual tune. Changed all the values in the transmission section over to the Camaros manual tune. Problem persisted.
When I log manual trans gear and auto trans drive inside the scanner they both change rapidly back and forth from yes to no. The PRNDL status stays on D4.
Any ideas would be greatly appreciated.
Thanks
Old Sep 19, 2019 | 09:23 AM
LSX Power Tuning's Avatar
We always flash over to a manual OS tune, will save you alot of headaches in the future. We use a 2002 OS for that and use either a truck or camaro tune depending on what harness you have. Its going to cost you more credits no matter what to do it correctly.
Old Sep 19, 2019 | 09:33 AM
Thank You, I will go hunt down a manual tune.
By Brett Foote | 2026-06-04 05:00:17
