O2 heater circuit error
02 Camaro H/C/I auto
Now I will say, you shouldn't be going into closed loop on right on startup. THAT is in the tune, but the heater circuit sounds mechanical, as most codes are typically. If you have access to the tune, you can increase the cold loop enable temps to make sure the O2's are heated up before going into closed loop. You can delay a few other tables too, but this would be the easiest.
Have you checked continuity and voltage on the heater wires? I'm assuming you have. This should be on as soon as you key on, without starting the car.
Side note I've recently found your videos on HP and I'm hoping to lean how to use it. Just probably not on this weird issue as I have no idea what I'm doing.
