Getting mass airflow and knock sensor code at same time.
Old Oct 27, 2019 | 10:16 PM
Mr. Demeanor's Avatar
Default Getting mass airflow and knock sensor code at same time.
2005 Hummer H2 6.0 with TRailblazer SS intake/TB/injectors, headers, full exhaust, and custom tune.
Last year I had a knock sensor go out so while the intake was off I had the shop swap it for the Trailblazer SS setup. It turned into a nightmare as the shop kept frying ECM's and my truck was there for almost two months.
Finally got the truck out of there with a preloaded ECM from Blackbear then took it to another shop for a tune that went well.
Now I am getting a CEL so I scanned it and saw mass airflow and knock sensor low voltage again :-(
I cleared the codes and it took a couple days but when the light came back on I pulled over and immediately scanned it. Same two codes.
It seems odd that I would get both codes at the exact same time.
Any ideas other than horrible luck?
Old Oct 27, 2019 | 10:46 PM
Just a weird thought.... check and see if those sensors wires run together and might be chafing against each other somewhere. Worth a shot...
Old Oct 28, 2019 | 10:49 AM
Just spoke with Glenn at Glenns Auto Performance where I bought the intake. He said both of those circuits come off the same side of the harness and to check the grounds at the back of the heads.
Old Oct 28, 2019 | 10:56 AM
I'm surprised I didn't use my best line, "Check ALL grounds!". I'm slipping.... lol
