Match a PCM to my swap - 16220610
Old Oct 28, 2019 | 08:54 PM
Bara's Avatar
Default Match a PCM to my swap - 16220610
Hello dear LS1TECH members!
I am trying to figure out what pieces I need to be able to run a 1999 LM7 with an LQ4 intake on it and DBW throttle body off the LM7. I have a way newer pedal and TAC module saved off a 2006 truck. My question is, am I able to program
SN 09354896 - HDW 16220610 PCm to run DBW?
The TAC is TMD1-160K1 - 12590008
The pedal is 15107594.
For any guidance I am very very thankful!
Cheers Bara
Old Oct 28, 2019 | 10:05 PM
Usually the module, pedal, and TB should be the same year. Though if the module and pedal were running with the same model TB as on the previous engine there should be no problem.
Old Nov 3, 2019 | 01:55 PM
Bara's Avatar
After another junkyard trip, I scored an 04 Tahoe PCM with 3 bar map and flex fuel unlocked, throttle body, pedal, tac, flex sensor, flex injectrors and rails and harness. Now to make one healthy wiring out of 4!
