Tuning VE - 0411 12202088
Old Nov 17, 2019 | 02:08 PM
Scott68B's Avatar
Default Tuning VE - 0411 12202088
Hi everyone
Quick question to confirm my understanding of the details on how the logged LTFT & STFT data is applied to the VE table. So does the LTFT & STFT data at a given MAP/RPM represent a percentage of the correction needed to that cell? Would one sum the average LTFT & STFT values, determine the percentage and then add (or subtract depending on a positive or negative percent) to the existing value in that cell? I read the "VE Tuning Using Fuel Trims" document and it isn't quite clear to me if the above is correct.
Thank you!
Scott
Old Nov 17, 2019 | 09:39 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by Scott68B
Hi everyone
Thank you!
Scott
If you are using HPT, the values do correspond to a percentage. Normally you only want to multiply by half, in order to avoid over correcting. If you are using other software, then?
Old Nov 17, 2019 | 11:18 PM
Scott68B's Avatar
Yes, I'm using PCMHammer/LS Droid/TunerPRO. I'm adapting an old Excel spreadsheet to apply the values. Good point about multiplying by half. Thank you for the response!
