Wideband reading 5v all the time
Old Jan 10, 2020 | 10:45 PM
cmarris2142's Avatar
Default Wideband reading 5v all the time
I have me aem x series wideband installed, the gauge reads fine, 14.7-15 at idle. I tried to wire it into my ac pressure switch, I wires the white wire from the sensor into the red/black wire on the sensor. When the sensor heats up, it reads 5v constantly but the gauge still reads 14.7, is it a bad gauge or what?
Old Jan 11, 2020 | 06:25 AM
ChopperDoc's Avatar
Did you ground it? I want to say it’s the brown wire from the gauge.
Old Jan 11, 2020 | 12:41 PM
I didn't think you had to ground it, nobody mentioned it in the write-ups I was reading
Old Jan 11, 2020 | 01:27 PM
ChopperDoc's Avatar
Try running it straight to a ground and see if that does the trick. Mine is grounded on my HPT Pro input, pin 5, and the signal wire on pin 1, so I know it uses one. You don't have to run the ground into the sensor, as far as I know, but it should still be grounded to something.
Old Jan 11, 2020 | 01:46 PM
Ah I see, I'll try that, fingers crossed
Old Jan 11, 2020 | 02:45 PM
Ran it to a chassis ground and it's reading now! My next question is do I need to run it to the sensor ground for proper offset or will it work fine on body ground?
Old Jan 11, 2020 | 03:44 PM
ChopperDoc's Avatar
If it's reading, then you can ground it pretty much anywhere solid. After that, make sure the gauge matches the input in the scanner, or is close with the correct transform. If you look in my signature, I have guides for this stuff, one such guide covers how to get the input into the scanner and make it match the gauge. Only change the offset to match the gauge.
By Brett Foote | 2026-06-04 05:00:17
