Need help. No start, has everything.. ready to smash
What am I missing??
understanding that it ran before the transmission was replaced , can an internal trans electrical problem cause this ? I'd actually like to know this .
other than that ....it sounds like the cylinders are washed down , maybe a few squirts of eng oil per cyl. ?
and how did that compression check go.
Have you verified that the injectors are squirting fuel? Have you tried spraying carb, or brake, cleaner into the throttle body while someone else cranks the engine over?
I've built a few LS engines and it seems the injectors, when left to sit with old fuel in them will plug up in a short period of time. Not kidding. I've had this happen twice on two different builds. At least on the 2nd build, I knew why it would not start.
Also, pull a spark plug out, reattach the plug wire, and hold it against the engine while someone cranks it over.. Watch for spark. If no spark, at least you know where to look.
