2002 5.3 need help!
Old Mar 24, 2020 | 06:11 PM
Gooseit's Avatar
Default 2002 5.3 need help!
Hey guys. First of all I have a 2006 5.3 in a 2002 Chevy Silverado. I just put new main bearings, push rods, lifters, cam bearings, a mild cam. Basic rebuild stuff with a new 4l65 tranny. Here’s my issue. The cam I put in is for a model with the camshaft position sensor on the front of the timing cover and the one I have is behind the intake manifold and the timing chain gear is different to read the cam. A position sensor error kept coming up so I swapped all the things to the newer sensor: gear and cover but it’s still reading low circuit on the cam sensor. Sorry if I’m not supposed to post this because it’s a Silverado but I just need help
Old Mar 24, 2020 | 08:59 PM
minytrker's Avatar
You may need to switch the outside 2 wires on the cam sensor plug.
Old Mar 24, 2020 | 11:09 PM
Gooseit's Avatar
will give it a try! Thanks, I’ll update tomorrow
