New engine questions/issues
Second issue i am having is a check engine light from a PO103 which is a MAF high circuit. I checked the wiring for damage as well as replaced the MAF and the code came right back. The car also seems to randomly stall when coming to a stop or when your cruising and just shift into neatural.
anyone have any solutions or ideas on where to start?
thanks in advance for the help
For the codes, unfortunately 99% of the time it’s a physical issue and not a tune. However, without seeing a log or tune file, tough to say really. The O2’s won’t help you for stalling, especially if the engine is flooding or what not because of shoddy readings. I can’t count how many threads are in this forum of similar problems because of bad O2’s. Typically exhaust leaks and super rich readings on one bank, etc, and the occasional flat lined one as you are describing. The shop that tuned it probably should of verified the wiring was right. Got to check the pins, PCM model, year, all of it to be sure. As I have found, P01 PCM’s don’t all have the same pin outs through the years, which is a real pain in the ***. Depends on what it was installed in in the first place.
