reprogrammers for that hp?
Old Jul 16, 2004 | 12:54 AM
ws62001ta's Avatar
Default reprogrammers for that hp?
ok as of the other day i recieved a huge check and wanted to hp it up. so i started looking at the programmers and now i cant make up my mind, if anyone knows of the best one plz post.
Old Jul 16, 2004 | 01:44 AM
horist's Avatar
what do you want? do you want a handheld programmer... or do you want a tuner package?
Handheld programmers are easy, minimal if any learning curve, but you can't modify everything
Tuner packages (such as HPTuners www.hptuners.com) require a laptop, steeper learning curve, but you can do anything you want ...
if you want a hand held unit I've heard very good things about this unit:
http://www.vincihighperformance.com/...FO%20PAGE.HTML
if you want a full tuner package (and are willing to take the time to read this section and learn what to adjust and why) then I'd suggest
http://www.hptuners.com/ (requires a laptop)
if you just want to get the most hp out of your current setup and don't want to learn how to use a full tuner package then you'll want to do a full dyno tune .. i'm not sure where you're located but there are many shops thorughout the country that can provide good tunes...
