Intermitant P0336
Old Apr 18, 2020 | 08:57 AM
Samtau's Avatar
Default Intermitant P0336
I have a 2006 LQ4 6.0 that i get an intermittent P0336. The engine starts and idles great but after about a minute of running it starts to miss then it throws a P0336 code. I can see the tack go erratic and jump 500-1000 rpms. If i let the engine get up to temp shut it off, rest the cods she runs great. Any help is greatly appreciated.
Old Apr 18, 2020 | 11:54 AM
B52bombardier1's Avatar
Bad crankshaft position sensor, circuit A. And you have a few of the symptoms. Needs to be fixed soon unless you have free towing, a bicycle or enjoy walking.
Rick
Old Apr 18, 2020 | 11:58 AM
Samtau's Avatar
I bought a a new crank sensor and replaced it and still had the problem. I then pulled a crank sensor off of my Yukon that I know it was working and still have the same problem
Old Apr 18, 2020 | 02:30 PM
Then it is a bad connection somewhere. Check ALL connections
Old Apr 18, 2020 | 02:49 PM
Samtau's Avatar
I've taken the ground off the back of the block and sanded it down two shiny metal. Where does the ground go into the fuse panel and ECU? I was reading somewhere about voltage drop testing but not sure how to do that with a hall sensor.
Old Apr 20, 2020 | 12:35 PM
Samtau's Avatar
Anyone have guidance on how to do a voltage drop test on a crank/cam sensor?
