E38 ECU manual vs automatic
I'm trying to use a E38 ECU from a Camaro 2013 with manual transmission in a enginge swap project with a 4L60E transmission. The problem I have is that I don't get any speed signal which in turn mess up the shiftings of the automatic transmission. Replacing the ECU with another E38 works fine so the problem is not the harness or anything outside the ECU.
Is there a diffence in the OS (not the tune) between a E38 ECU for manual and automatic?
Thank you for any tip or help!
