Startup Tune Advice
Deka 60lb injectors. Looking for what else I need to change to be start up ready. Starting with a stock tune.
Stock displacement 9.3:1 compression built bottom end with stock heads 100mm TSP lsx maf Deka 60lb injectors.
I have the start up numbers from TSP on the 100mm MAF added to a bone stock tune airflow vs freq table. I have been having issues finding numbers for the Siemans Deka 60lb injectors. On HPTuners I found a tune from a 2002 iron block using the same injectors. I have all 2002 injector numbers added to the "injector control" section. I have not touched the "cranking fuel" section because the 2002 table is different than my 2000 table. Should I adjust the cracking section?
Flow vs kph on the data I pulled starts at 72.6 and increases in that chart. Everything I have seen suggests the flow vs kph numbers should be close to your injector size. 72 seems large for a 60lb injector.
2000 ss camaro CAM,long tube headers D1X prochrger, FMIC.100mm TSP maf. ls6 intake. its a built short block with stock heads.9.3:1 compression
Thanks for any help
I used the deka numbers and the tsp 100mm maf numbers they sent me. The car started and died. So I stopped.
I sure would. I’d really like to learn to tune. Chances are I could do it. But I would really like to get the car on the road. I’m debating just going to a tuner. I know now it wouldn’t idle because I didn’t adjust for the cam. I’m make a few more tweaks and try again.
