Engine Dies After Startup
Drove the car home after the dyno and 1 week later it started acting like this where it wouldn't stay running after startup.
Car won't run long enough to get a real log file but let me know if that would do any good... Tach reads fine... I don't know if this is a crank sensor issue? Don't know where to start as fuel and spark seem fine. Grounds on the head are still there.
Tune file is attached.
I attribute the start/stall to a huge vacuum leak and/or fuel leak. Once I replaced the orings with 5.3l truck style, the injectors fit perfectly and the car fired up and ran perfect. I purchased the initial replacement orings from ebay listed as "Bosch 210 replacement o rings". They fit just fine on the injectors, but would not seat into the manifold very well at all and caused all kinds of issues. Generic truck style orings was the "fix".
