No throttle peddle control
I have a 2010 Camaro SS with a 417 The issue I am having is when I try to power break the car the gas peddle is dead but only in drive.
The car will drive just fine until you put your foot on the break then the gas peddle wont work It will rev up fine in P R N just not drive. If I use the line lock it will work ok I have tried turning off tcc and pulling fuse 40 and 43 the only thing that helps is if I unplug the connector on the break peddle under the dash but the I have no break lights
Anyone have this happen to them or have any ideas
