Problem when detune MAF
Old Sep 28, 2020 | 01:37 PM
M Ericsson's Avatar
Default Problem when detune MAF
Hello,
I have this swaped gen 3 P59 engine stg2 cammed with NO maf, no O2 at all. With some tweeks to the tune this engine starts and idle just fine at 900. Now to the problem, If I set maf failure frequenzy to 0, engine will start fine, but idle like 400 rpm 3-5 s then die. I tried some different fuel settings and got the engine to loop like crazy for maybe 10s then die.
any thoughts?
Old Sep 28, 2020 | 01:40 PM
ddnspider's Avatar
You need to be tuning the VE table when you disable the MAF to get the AFR correct. All fuel trims must also be disabled.
Old Sep 28, 2020 | 01:46 PM
M Ericsson's Avatar
I have disabled closed loop, stft, ltft, I also have connected wideband.
how do I disable all idle adaptives?
I'd like to know why the emgine runs so good without the fysical sensors, but when I fail them in tune engine runs like crap?
Old Sep 28, 2020 | 02:11 PM
ddnspider's Avatar
Its running like crap because you failed the MAF and don't have a tuned VE table.
Old Sep 29, 2020 | 10:49 PM
andy burdess's Avatar
If you’ve got a wideband I can help you out
