IQ3/Dominator no data
1. Street dash shows pins 17 and 25 as can hi and low. Page 33 of the iq3 says pin 26 is the can lo. Pin list says 26 is ground, which I’m sure it is as I got fuel sending unit to work
2. i read that the ecu can outputs should only be switched to Racepak if going thru a V-net module. Should stay in Holley if using a Holley compatible device. Is the iq3 street dash a compatible device?
