NLS spark cut
Old Dec 6, 2020 | 08:03 PM
Z32_5.3's Avatar
Default NLS spark cut
Does anyone know if there is a single wire on the ecu that could kill spark at all coilpack?
going to wire in a no lift shift, do not want to use 2 ground wires at both sides of motor coil packs. Easier if I could interrupt a single wire at ecu to shut off the spark.
Old Dec 6, 2020 | 08:06 PM
AwesomeAuto's Avatar
You could interrupt the power wires. That's how my N2MB box did it.
Old Dec 6, 2020 | 08:27 PM
Z32_5.3's Avatar
which pins on ecu did you cut ?
Old Dec 6, 2020 | 08:29 PM
None. The coils get power directly from the battery/ignition, not the ECU.
Old Dec 6, 2020 | 08:42 PM
Z32_5.3's Avatar
I didn’t know. Makes sense though. Guess I’ll have to cut wiring at the harness clips. Hoping for a neater way.
Old Dec 9, 2020 | 10:51 AM
bubba2533's Avatar
What ECU are you running?
