HPTuners or ????
A good remote tune with a wideband should be no problem for a two hour drive to get the dyno tune. A LNC-2000 controller will allow you to have an optimal NA tune... along with the controller pulling timing for a N2o tune when the spray is armed.
As you go up in spray you can pull more spark via the controller then verify the tune with the wideband and plug readings. If you can install the LNC before the dyno tune, your tuner should be able to set the controller up for whatever shot you're spraying. This is much better than flashing a dedicated N2o tune when spraying and flashing back to a N/A tune when not.
