Trouble
Old Jan 4, 2021 | 12:00 PM
David Rose's Avatar
Default Trouble
Code 1637 has 1 wire alt will this affect pcm or dont worry
Old Jan 4, 2021 | 05:38 PM
B52bombardier1's Avatar
With the engine running and the headlights turned on (to load the alternator), what do you see for DC volts measured at the battery posts? Use a good multimeter. Hope for 13.8 VDC to no higher than around 14.5 VDC. Turn off the headlights and see what you get.
Rick
