Testing PCM pin 42 - fan trigger
I have a PCM out of a 2003 Chevy truck (6.0 gas). I am trying to see when pin 43 - blue connector comes on. I was told this is the pin for the fan relay and it is a negative trigger. I wired to a fan switch and the fan never came on... is there a way to see what it is programmed for or when it will / won’t come on with a scanner?
the prior owner hard wired the fan and I have confirmed the fan is triggered to come on with a ground to the relay, truck got up to about 220 / 230 and the fan didn’t kick on, so wondering if there is a way I can see what the computer does with that pin and when?
thanks for any thoughts you can provide.
