A/c bogs down motor
Old Mar 6, 2021 | 09:22 PM
vern6.0's Avatar
Default A/c bogs down motor
I have a 5.3/4l60e swap in a 74 c10. It's a non-air truck so I installed a nostalgic air unit. I charged it up and I wired it to where when I turn on the a/c both fans come on. At idle when I turn on the a/c the motor either bogs down or completely shuts off. When I drive I feel a load on the motor.. it has a sanden compressor Mind you I do have a pretty healthy cam with a 3200 converter. What do I need to do to give the ecm a signal that tells it the a/c is on and to make the engine idle higher?
