*TPS troubleshooting*
Old Mar 10, 2021 | 10:38 AM
rob-z71's Avatar
Exclamation *TPS troubleshooting*
i've got a 2002 LQ4 DBC swapped into my 1998 k1500 using a BP Harness. im in the process of working with a remote tuner trying to get her to run right. im having intermittent TPS problems so i decided to change the sensor but im still having problems. sometimes it works fine and i get normal readings, other times not so much. what i've seen in my initial troubleshooting from the 3 pins on the sensor are the black is reading ground which is normal, the gray wire is reading 5v, and the dark blue wire (signal wire according to the pinout) is reading 0.6v with the throttle closed and 4.4v as i held the throttle fully open. i dont know if these are normal readings. i also have an engine code for low TPS input or something i forget the exact alphanumeric code. any ideas??? thanks in advance
Old Mar 12, 2021 | 02:47 PM
RonSSNova's Avatar
Those are correct values.
