P0405 code
Old Mar 16, 2021 | 05:21 PM
Howertoday's Avatar
Default P0405 code
have a 2000 Trans Am. I've thrown the p0405 code a couple of times for low-voltage on the EGR valve. It seems to happen when I do a hard acceleration. Most often if I'm on the freeway doing 70 and then I punch it and kick it up to 90 I'm just take my foot off accelerator it starts coughing and choking and throws the code. I took it to a shop they seem to think it's something in the wiring harness but they haven't been able to find it. I think it might be something to do with a weak or bad motor mount that causes the motor to twist and pulling wiring somewhere does anybody have any thoughts
Old Mar 16, 2021 | 06:35 PM
Do you have smog inspection? If not, disable and remove the EGR system. It is not needed for the engine to properly function.
Old Mar 16, 2021 | 06:43 PM
Howertoday's Avatar
california car, I do currently have smog but by next year will need to have new inspection.
Old Mar 16, 2021 | 06:54 PM
Originally Posted by Howertoday
California car, I do currently have smog but by next year will need to have new inspection.
Oh OK. Check all related grounds, and any frayed/chewed up wires.
I feel your pain, also a Cali resident.
Old Mar 16, 2021 | 09:15 PM
tblentrprz's Avatar
Disconnect EGR and test to confirm no issue. Trace wires from EGR to PCM to confirm no issues. You could do a wiggle test while monitoring the EGR supply signals at the EGR and position sense signal at the PCM and look for erratic signal. If all good, replace EGR.
