New engine, old tune... safe to run?
Here's the basic comparison between the two motors:
Old motor
5.7 SBE LS6 block
243 heads milled .030 w/ steel valves and tool steel retainers
226/236 .600/.600 110 cam
ls7 clutch and fly wheel
Standard volume/pressure oil pump
New motor
5.7 SBE LS1 block
243 heads w/ ls6 valves, titanium retainers (no milling)
230/236 .600/.600 112 cam
Monster stage 2 clutch w/ aluminum fly wheel
High pressure pump
Everything else is basically identical. Again, I'm not planning on driving hard or anything, just trying to see if it's safe to start and drive for a bit to get it tuned or do I need to send off for a mail order tune. Thoughts?
And yes... I'm adding an accusump this time.
Your tuner may have to tweak a few things. Maybe add a smidge of timing at WOT.
I mean... how do I change platforms now? Lol
