Check engine light
Old Apr 29, 2021 | 07:51 PM
oldngray's Avatar
Default Check engine light
Does the ecu power the check engine light or ground it.......
Old Apr 30, 2021 | 07:36 PM
oldngray's Avatar
Default Light
Seriously... I figured to have a dozen answers by this time....
Old Apr 30, 2021 | 09:43 PM
tblentrprz's Avatar
Based on 2001 IC schematic, ECU gnds it. Not sure what vehicle you're working with.
Old Apr 30, 2021 | 09:55 PM
oldngray's Avatar
Ls conversion, aftermarket harness...no response from harness manufacturer, hopefully they are all the same, this is the first one that hasn’t come pre-wired....Thanks for the response....
Old May 1, 2021 | 04:22 PM
tblentrprz's Avatar
If setting up your own light (non factory dash) then need to know what PCM your using (not sure if factory PCM logic can be changed). If aftermarket controller, then configure as needed.
Old May 2, 2021 | 07:42 AM
oldngray's Avatar
Will check the color code, however I do know its out of an 04 GTO, m6...,
Old May 2, 2021 | 01:38 PM
oldngray's Avatar
My PCM is the blue/ green combination....."
Old May 2, 2021 | 05:36 PM
79LS1FOX's Avatar
e38 and e67 its a brown wire and its a ground.
 Michael S. Palmer
Old May 2, 2021 | 06:07 PM
oldngray's Avatar
I had it as the brown wire, no reference as to power or ground in the supplied paperwork/schematic...thanks, now can finish the dash
Is this specific to the blue/green combination, or does it work for all GM stuff?..
