how accurate is pcm reading of water temp
Old May 4, 2021 | 05:29 PM
Floorman279's Avatar
Default how accurate is pcm reading of water temp
recently aquired a multigauge, and deciding what 4 i want to display on the gauge. was curious if its accurate enough to go off of without buying an add on module and hooking up another sensor
Old May 4, 2021 | 07:46 PM
aknovaman's Avatar
I have found GM sensor are generally within 2-3 degrees of actual temp.
