Commanded idle stuck on zero in park
Old May 18, 2021 | 07:05 PM
VandykeT/A's Avatar
Default Commanded idle stuck on zero in park
To make a long story short I tuned a 2000 M6 Trans am then it got crashed and the engine and ecm was put in a 05 Mustang with a 4l60e behind it with a standalone harness. So I tried to do a segment swap to get the trans to work but couldn’t. So I did a write entire from a 2000 auto car and copy and pasted all of the engine side things over and the car does fine other than when started the commanded idle stays on zero and the car won’t idle. I can throw it straight in gear and commanded idle will climb to 900 like commanded and I can go into park after that and it’s fine until the next key cycle. Basically first start up in park neutral the commanded idle is zero pull it in gear it climbs straight up then it’s fine until you turn off the car. Any ideas? On his standalone harness he even tried grounding the shifter wire direct and still zero until it’s put into gear.
