How much tuning do I need to do
LQ4 with 36lb injectors and an LS1 intake
The mods I’m making:
243 heads w/ PAC 1219 springs
Sloppy Stage 3 cam 238/242, 595"/.595", 112 LSA
Atomic MSD Intake with 102mm TB (DBC)
I have HPTUNERS already. Just curious how much it’ll be off. Will I need to do a whole new tune just to get driving to a dyno?
Any help is greatly appreciated.
To begin, it's going to be rich down low and lean up top, that's just how it works with the mods you made. The injector data will need to be corrected, the idle airflow will need work, the idle tip in and timing will all need work.
Can you drive it? Maybe. Would I, No.
Tuning is a steep learning curve if you don't understand the basics of the mechanics. The camshaft changed the efficiency of the engine. It's now less efficient down low, more efficient up top. The heads also play a part in the airflow, and combustion compression. You went from around a 9.5:1 to around a 10.5:1 ish setup. That's just 2 parts, not to mention the air intake track, filter, exhaust ECT. Your looking to have say less than 3% error, you probably have upwards of 20 in places now if I were to guess. The ecm just can't correct for that.
